Seite 5 von 6
Verfasst: Di 4. Aug 2009, 19:33
von nöggi
Grüezi,
hab im Net einen guten Beitrag zum Thama Farben gefunden,
bring wieder etwas mehr Klarheit in die Sache, viel Spass beim schmökern
grüsse
bruno
Giulia paint codes
source :: John Hertzman - http://www.alfaclubdc.com/superpnt.htm
"I am hoping to paint my Giulia 1300 Super a different color and would prefer something that Alfa used on the various renditions of the Super."
Alfa published a Body Shop Manual (#1570) covering Giulia and 1750 cars (Arese-built 105s; the bodywork details do not cover Spiders or 101 Giulia Sprints/Sprint Speciales). The manual included a list, implicitly comprehensive, of the company code numbers and names used at that time for thirty-three colors used on Giulias and 1750s including Spiders. (There were other company code numbers used for some of the same colors in an earlier period.) The Spiders all had Pininfarina colors, normally identified as P.F., none of which were used on Arese cars as far as I know except for the AR 103 ivory which was added to the full range later, I believe with the introduction of the 116 cars. That leaves twenty-seven colors which would have been used on 1600 Giulia and 1750 sedans and coupes through the date of publication (9/70); it also includes most but not all colors used on the later 105 sedans and coupes which were built as late as 1976.
The following list includes the AR numbers and both Italian and English names used in the manual; second AR numbers in parentheses are for the same colors in the earlier numbering system. Names in parentheses are other names used for the same colors on factory color chip charts I have. Following numbers in parentheses are Ditzler (PPG) and/or DuPont code numbers (from the paint manufacturers' lists as of mid-eighties) that I have for the colors; where no Ditzler or DuPont numbers are listed they were just not listed at that time, and had presumably been dropped early on. Terminal name notations are from the paint manufacturers' lists. All of this information is from Alfa sources or paint manufacturers' lists, none from secondary sources, but I can't guarantee accuracy beyond that.
AR-008 Bianco P.F.- Farina White (China White) (Ditzler 8331, DuPont 37000)
AR-013 (AR 101) Biancospino- White (Chalk) (Ditzler 8812, DuPont 8654) (also called Hawthorn)
AR-103 Avario P.F.- Ivory (Straw) (Ditzler 81870, DuPont 37001)
AR-109 Giallo Ocra- Ochre (Ditzler 81618, DuPont 8769) (also called Autumn Gold)
AR-112 Ocra Scuro- Dark Ochre (Ditzler 23934, DuPont 8733) (also called Caramel)
AR-113 Giallo- Yellow (DuPont 8734)
AR-114 Biondo Champaigne- Champaign Blonde
AR-209 (AR 601) (AR 227) Verde Muschio- Dark Green (Moss Green) (Ditzler 44158, DuPont 8774)
AR-213 Verde Oliva Metallica- Olive Green Metallic (DuPont 8736)
AR-216 (AR 605) Verde Pino- Pine Green (Ditzler 43782, DuPont 8775)
AR-217 Verde Vivo P.F.- Green (Ditzler 44363)
AR-301 Celeste P.F.- light blue
AR-323 Bleu P.F.- Farina Blue (Skipper Blue) (Ditzler 12584, DuPont 37004)
AR-324 (AR 508) Blu Cobalto Medio- Medium Blue (Ditzler 13526, DuPont 8868)
AR-327 (AR 506) Bluette- Petrol Blue (Ditzler 12955, DuPont 8773)
AR-330 (AR 504) Azzuro Spazio- Space Blue (Ditzler 13941, DuPont 8869)
AR-342 Blu Francia- French Blue (Ditzler 14158, DuPont 8737)
AR-343 Blu Olandese- Dutch Blue (Navy Blue) (Ditzler 13939, DuPont 8738)
AR-501 (AR 303) Rosso Alfa- Alfa Red (Ditzler 71818, DuPont 8772)
AR-509 (AR 308) Rosso Amaranto- Amaranth (Plum) (Ditzler 50772, DuPont 8771)
AR-514 (AR 304) Rosso Italia P.F.- Farina Red (Signal Red) (Ditzler 72051, DuPont 8770)
AR-516 Faggio- Dark Maroon (Ambassador Maroon, Aubergine, Ambassador Red) (Ditzler 50842, DuPont 8739)
AR-537 Blu Chiaro Met.- Light Blue Metallic (DuPont 7808)
AR-701 (AR 505) Acqua di Fonte- Springwater (Ditzler 13942)
AR-716 (AR 705) Grigio Grafite- Graphite Grey (DuPont 8776)
AR-724 Grigio Beige- Beige
AR-727 (AR 748) Grigio Chiaro Met.- Medium Grey Met.(Silver Metallic) (Ditzler 32838, DuPont 43078)
AR-728 (AR 749) Grigio Medio Met.- Silvergrey Met. (Ditzler 32764, DuPont 43978)
AR-735 Grigio Indaco- Grey (Ditzler 33093, DuPont 8743)
AR-736 Antracite Inglese- English Graphite (Ditzler 32767)
AR-818 Bruno Fondo- Maroon
AR-821 Beige Cava- Beige (Desert beige) (Ditzler 23931, DuPont 8746)
AR-901 Nero- Black (Ditzler 9000, DuPont 99)
New colors on the 1972 2000 chip chart include:
AR-119 Canary Yellow (on Spider only) (Ditzler 82112, DuPont 44344)
AR-219 Racing Green (on Spider only) (Ditzler 44848, DuPont 37003)
AR 510 Carmen Red (on Spider only) (Ditzler 72052)
AR 525 Raspberry (GTV only) (Ditzler 50917, DuPont 37015)
AR 827 Champagne Metallic (Berlina, GT) (Ditzler 23933, DuPont 37022)
The only colors I can find which were used on the Supers which are not on this list are AR 116 Giallo Piper, called Topaz here, (Ditzler 82113, DuPont 37006) and AR 348 Azurro Le Mans, Le Mans Blue, (Ditzler 14637, DuPont 37011). There were very few other colors used on the 105/115 sedans and coupes, the only one I am aware of being Bleu Pervinca Metalizato, Periwinkle Blue Metallic which does not show up under that name on the paint companies' lists but is I believe what they both call Peruvian Blue Metallic, AR 349, (Ditzler 14638, DuPont 43980).
Best place to view the colors that I know of would be your Sikkens dealer- they have a very effective color grid system - but I would leave off the Ditzler and DuPont codes when visiting them, and personally would probably use either Sikkens or Glassurit paints unless my paintshop was partial to Ditzler or DuPont products.
HTH somebody -
John H.
Verfasst: Sa 24. Apr 2010, 10:20
von nöggi
Hi Volker,
geworden ist noch garnix. Die tragenden Teile müssen alle nach und nach herausgetrennt und gewechselt werden. Die Träger unter den Bodenblechen sehen von der Seite aus wie Krokodilgebisse!!
Das braucht noch mehr Zeit und mehr Kohle und im Moment hab ich nur noch Zeit übrig, da das Geschäft einige Investitionen benötigte, guckst Du unten!
Aber es hat auch sein Gutes (man findet ja immer was wenn man genau genug sucht). bin nämlich vom Ginestra 113 nicht mehr restlos überzeugt.
Erstens weil der Chrom nicht so zur Geltung kommt und 2. !!Citroen spritzt neuerdings den Jumper in genau der Farbe :eek: !! Wir haben im Dorf einen Schulbus, da konnt ich mit meinem Muster vergleichen, jetzt stell Dir vor ich hätte schon gemalt!! Und plötzlich wäre das Auto voller Kinder! bin ja kein katholischer Geistlicher :D
Hab unterdessen aber was gaaaanz schönes entdeckt: AR-312 (1960-73), AR-328 a.k.a. Blu Zagato (1970-71), AR-347 (1973), könnte gut auf den Duetto passen.
Die Infos hab ich übrigens von dieser sehr informativen Seite, viele Farben mit Codes und grossen Farbmustern. Ein Klicken lohnt sich sicher:
http://www.alfabb.com/bb/forums/car-res ... als-2.html
Werde also die diesjährigen Feierlichkeiten nicht im Duetto erleben können
allerdings trotzdem in einem Alfa und nicht mehr im Röno, guckst Du
gruss aus der Schweiz
Fotos der AR Farben ....
Verfasst: So 1. Mai 2011, 16:46
von roby
Hallo,
nöggi hat zu den verschiedenen Farben entsprechende Alfa-Romeo Fotos zusammengetragen.
Schaut doch mal rein. Falls ihr weitere Farben und/oder Fotos habt, dann nur her damit :-)
http://www.duetto-club.ch/autoinfos/farb-muster/index.html
Grüsse
Roby
Verfasst: Sa 18. Feb 2012, 15:54
von Dirk Roissl
Hi Duettisti!
Die Restauration meines 1750er Veloce steht nun unmittelbar bevor - endlich...
Die Auslieferungsfarbe war ursprünglich AR 323 P.F. Blue, momentan befindet sich lt. Vorbesitzer "Blue Cord" auf dem Blech (ich glaub das war gar kene Alfa-Farbe oder?).
Ich bin eigentlich ein Originalitätsfan, liebäugle aber auch sehr mit der Farbe AR 105 Giallo Paglierino 1958 - 1993, im Farbarchiv ist sogar ein US-Duetto mit dieser superschönen Farbe zu sehen. Die Sicken und Kanten kommen damit viel besser zur Geltung als mit dem Pf-Blue, aber das sieht man auch sehr selten und hat deshalb natürlich auch seine Reize...
War AR 105 Giallo Paglierino beim 1969er Spider 1750 Veloce original zu haben oder weiss jemand vielleicht bei welchen Autos diese Farbe Original bestellbar war?
Vielen Dank für Eure Hilfe,
Dirk aus dem winterlichen Kärnten.
Verfasst: Mo 20. Feb 2012, 07:28
Hi Dirk
es gibt Leute die sagen, dass man die Duettos in allen zu dieser Zeit lieferbaren (Alfa-) Farben bestellen konnte. Dies kann durchaus sein.
Fact ist aber, dass es Farbkarten gab, wo die offiziell bestellbaren Farben drauf waren. Diese Farbkarten konnten im Detail von Land zu Land verschieden sein.
Wenn du deinen Duetto wieder in der original Farbe lackierst kannst du nicht viel falsch machen. So ist das Auto auf die Welt gekommen, so ist es dokumentiert, also warum auch ändern...
Aber schlussendlich muss dir selber der Duetto gefallen. Und so ist es auch aus meiner Sicht legitim, einen Duetto in roso oder pink zu lackieren, Hauptsache es gefällt dem Besitzer.
Liebe Grüsse
Verfasst: Mo 20. Feb 2012, 10:22
von nöggi
Hi Dirk,
laut meinen Recherchen und der Aussage von Marco Fazio vom Centro Storico war es möglich, jedes Modell in jeder zum Zeitpunkt der Montage verfügbaren Alfa Farben zu bestellen. Bei älteren Farben (nicht mehr im Programm) wäre ich mir da nicht so sicher.
Die Duettos wurden ja bei Pininfarina zusammengebaut und lackiert, deshalb alle Pininfarina Farben. Dann in Arese endmontiert.
Für andere Alfa Farben gingen die rohen Karossen zurück ins Werk und wurden dort lackiert.
Deshalb sieht man in einem "GT Buch" in der Lackier-Strasse auch Duetto Karosserien in zB. Giallo Ocra AR 109.
Giallo Paglierino wurde sicher auf den Giuliettas lackiert und sollte bis 1971 erhältlich gewesen sein, wäre also möglich.
Grundsätzlich ist festzuhalten, dass die Farben der frühen 60-ger Jahre eher blass mit mehr graustich (schwarz beigemischt) hergestellt wurden (auch die 1600 Duettos z.B bei Verde Muscio) , gegen ende der 60-er wurden die Farben klarer, kräftiger und bunter (z.B.1750 Verde Pino).
Ich persönlich finde Paglierino sehr schön und hätte das auch beinahe lackiert, bin dann aber auf eine kräftigere Farbe umgestiegen da ich auch einen 1750 aus 1968 restauriere.
Bei einem 1600er hätte ich Paglierino genommen, oder Acqua di fonte.
Bin sehr gespannt wie Du Dich entscheidest, bitte stell doch ein Foto ins Forum wenn so weit ist. im Übrigen finde ich es toll wenn die Duetto Palette etwas bunter wird.
gruss
Ciao Dirk
Verfasst: Mo 20. Feb 2012, 15:08
von sandro martino
Mein Tipp nero AR 901(Mit roter Innenausstattung der Hammer) war orginal und wurde nur auf Wunsch lackiert.
Die meissten Duettos sind sowieso rot oder weiss !
Noch eine schöne Farbe wäre Giallo Prototipo AR 119
Wünsche dir viel Spass bei der Qual der Farbwahl !! ;)
Verfasst: Mo 20. Feb 2012, 15:18
von nöggi
Ciao Sandromartino,
mit dem Schwarz has Du recht, sieht mit roter Ausstattung super aus.
Giallo Prototipo gabs leider erst ab 1970 für die Fastbacks.
mögliche Gelb:
1962 - 1993 Paglierino 105,
1962 - 1972 Chiarese (Ginestra) 113,
1965 - 1979 Ocra 109,
1965 - 1969 Cina 104,
1967 - 1969 Ocra scuro 112
1967 - 1973 Giallo Oro 117
gruss
Hallo Volker
Verfasst: Mi 22. Feb 2012, 07:25
von sandro martino
Hatte früher auch mal einen 1750 in Rot und einen 1600 Duetto in Weiss.
Das sind beides sehr schöne Farben aber immer wenn mir mal ein anderer Duetto entgegen kam(bei mir ganz selten) waren diese halt auch in dieser Farbe.
Mein aktueller 1300 Junior (901 nero mit roter Innenausstatung) habe ich in Italien vor ca. 2 Jahren gekauft.Einzig das lackierte Armaturenbrett kommt in jeder anderen Farbe besser zur geltung !
Gruss Sandro :cool:
Verfasst: Mi 22. Feb 2012, 10:25
von Dirk Roissl
Vielen Dank für die zahlreichen Antworten!
Ich hab so das leise Gefühl ich werde Volkers Rat befolgen und die Originalfarbe wählen. So ist er ja auch auf die Welt gekommen.
Ich werd mich sicher in der nächsten Zeit des öfteren melden und um Rat fragen ;-)...
Tanti saluti a Klagenfurt am Wörthersee,
Dirk
